Similar Topics
By gatorschevy
I own a few older quads mix of kinds a couple of Yamahas, a Honda, can-am a Kawasaki, they are older quads but in good shape the question of the day is....... what's the best way to polish up the plastic?
By Matman
First time working with a Honda-Matic transmission. I didn't even know what I was getting into when I purchased this running beat up farm workhorse quad with black oil. I was thinking I could tear the cases apart and find the bad bearing, causing the random squealing noise when you put it into gear and give it gas. Upon opening the engine covers, I Learned about the Honda Matic automatic transmission and realized there's more than just an electronic shift motor going on in these quads. With my learning curve in major education mode, I'm now wondering two possible culprits to the squealing as I've torn the motor down and am staring at the Honda Matic transmission.
Two possible issues:
1. The bearing that is squealing is unfortunately inside the hondamatic unit hydraulic transmission which is apparently not serviceable? A new unit is $1,900 to replace it! Yikes!
2. The pull starter rope snapped and someone replaced with the wrong pull starter rope that eventually became severely worn out and the centrifugal lever/catch shows signs of wear from rubbing against the housing.
Thinking now the pull starter has nothing to do with a squealing that loud, so my attention is now on the Hondamatic unit,
Has anyone gotten inside their cases to inspect the Honda Matic transmission?
There's a only 1or 2 videos out there that are not helpful for tear down and inspection.
I understand it can't be rebuilt but wondering if anyone has looked deep enough into one to clean it out from running dirty oil? Possible identify bad parts.
I refuse to believe Honda is engineeering these as completely non-serviceable?
Thinking I will try to disassemble the Hondamatic unit m. Hopefully get into it and get all the dirty oil out and replace with fresh? Any special tools needed?
Any and all thoughts/experiences with Hondamatic units would be great conversation for me..
By Fiend_138
Anyone using the AtV/Motorcycle lift from Harbor Freight? I like the idea of having something other than jack stands. Is there another option that I should look into?
https://hftools.com/app60536
By Yammy
Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
Let me know, I'm new to this.
Thanks!
By Superk
Purchased a Ranger 150 for the kid and searching info online came across this site. Looking to update the fleet next year with a Turbo SXS.
This is an upgrade from the Polaris Outlaw 50.
Similar Tagged Content
Gallery Images
2
0
7
2By LT250R,
1By Guest,
9
3
3
5
8
3By oxidized_black,
8By onebad400ex,
3By SYKOLINCOLN,
13By quadcrazy,
4
3
4
0By Shortcut,
1By LT250R,
1
