  • Admin changed the title to Hisun PQV400 Quad Service Manual
I don't have a manual for that model but other 400s also say to align the dots.. Are you sure there isn't any faded dot there. Even though it says it's a punched dot, It may have been an etched grey dot which might be hard to see now it's used. If it is a hole and a punched dot then they should be easy to spot. If the marks aren't there, perhaps they decided it wasn't so crucial anyway and dispensed with the marks.
There are a few reasons they insist on aligning things like that, one is for balance and  another is critical manufacturing clearances. The other likely reason for that part having marks would be because the springs aren't exactly equally spaced. If the springs were exactly equally spaced it could get a rhythmic pulse or vibration in the drive. To prevent that they sometimes make the spacing just very slightly different as it goes around. It may be that those two parts fit together anywhere, but some places only some springs will be under a lot of tension and others will be contacting lightly. If it's put together correctly every spring will be taking equal load even though the spaces between gaps is different.. I'd check that.
Hi Mech, thanks for your reply!
the thing is I’ve got a brand new crank and there’s no marks on either of them where stated, but the balancer has to be in time with the crank correctly or a: it wouldn’t cancel the vibrations it’s designed to and b: it hits the crankshaft web and journal, the web is clearanced to allow the balance weight to pass . I’d assume with the crank at TDC  the balancer would be centrally in the crank web and opposed at BDC, but assuming can be dangerous  lol.
have a great day!
Oh. That's a pickle then. Are the parts after-market ?
And yeah the balancer will just miss the crank. That gives you some idea about where it's meant to be.
Well.. Reading around it looks like that engine is a copy of a yamaha, and the yamaha says to align the dot on the gear with the key in the shaft.  That would also mean that when installing it the key would be aligned with a dot on the other gear.
    • By cavry
      Cavry
    • By noticon75
    • By Shorty51
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
