Try turning in the rebound damping screw on the lower part of the shock using a flat head. Try it one click at a time until it feels better. I just had to have my BF do it on my warrior because my shock was too slow, not rebounding fast enough. I had the opposite problem.
all i see is a turn thing at the bottom of the shock/strut
Not sure where the rebound adjustment is on your shocks, may be at the top, look at a pic of the OEM micro fiche. Or if u have a manual but try adjustin it before getting the thing all rebuilt. :yes:
i know what you mean, its almost impossible to turn the thing when its on the shocks
That's one way!? I was gonna say if you are by yourself, rubberband the front brake so it is applied. Set the grab bar on a ledge that will be high enough.
or apply the parking brake.. smae as the rubber band. thats a good idea:yes:
    • By crankin
    • By Gtc4d
      Thanks.
      Todd
    • By harryjr
      hello everybody my name is Harry jr and i recently picked up a 90's Yamaha moto4 225 i beleive and neede a starter was all he said ( i know right ) thats what they all say
      anyway i picked up a starter and installed it and when it is crankling it sounds as if it is not turning over freely as i9f there was a one way bearing not worrking correctly so pulled with recoil and it pulled back so hard i ripped out of my hand so hard it actually hurt now i have pulled and kicked a lot of bikes and such but never felt anything quite like this you can hear it try and fire and kick back but still acts as though somthing holding it back does that make any sense to anybody is it flywheel key , or valves wauyout any help would be great i picked tow of these up for $100 and tring to fix so we can ride as a family thank you in advance.
    • By jordan_ATV
    • By Vlaco
      Hi. I just joined the community. I have a sheep farm and use a Polaris 500HO, Polaris 700efi and a JD Gator 825i for different jobs around the farm. I do all the repairs myself so I am sometimes needing some advice and maybe I can be of some help to others as well.
