Edited by Admin
Long topic title, moved to Kawasaki ATV forum
  • Admin changed the title to 1990 Kawasaki Bayou 300 Intake and Exhaust Pop
So it had this same problem before you replaced the carb twice, and did the head up ?
Initial impression, since it's popping out the inlet and exhaust, would be that your ignition is failing.. It might be that the ignition timing is going erratic.. I think I'd put a timing light on it and watch the timing and that the spark doesn't fail as I rev it up. Could be the cdi or a wiring fault.
You could also check the charging system is regulating as it should.
  • 2 years later...
I know this has been a while, but if anyone else need this info. I had a similar problem with one of our 86 KLF 300A. I could not get it to start. It would fire then sputter or backfire. I took carb apart and cleaned and adjusted valves and put in fresh gas and spark plug. I was able to get it running but it was not running good and would backfire. After running I saw smoke coming from behind battery. What I found was a chafed ground wire grounding out on frame. Tracing the wire it went into left engine cover. I assume the pickup coil was not grounding properly. Fixed wire and now it runs great.
Thanks for the info. Great you found that lucky it didnt take out the pick up coil and CDI. It must have been only touching momentarily every so often.
    • By Elk
      2002 Polaris Magnum 325
    • By DexKing
      Good day everyone!
      I am pretty new to ATV/UTV/Small engine repairs and would like input on your absolute must-have specialty tools for maintenance and repairs. Aside from the obvious wrenches and sockets, what are some more specialty type tools you use for troubleshooting? I don't plan to open a repair shop or anything, I just do this as a hobby. Looking forward to your responses!
    • By kevinohio
