Subscription option in Quick Reply
Similar Topics
By BuckBilly
By Buell
Hey guys, figure you guys would have some helpful direction or answers.
So, 05 Sportsman 700 carb, new carb, fuel pump, new plugs, new air filter, new everything I can think of that is usually the running issues. Starts up fine, seems to run fine, but if under load, two people, or even one person, up a hill, or pulling a drag chain for the driveway, it starts to cut out and sputters and loses all power, until I back off on the throttle and just barely try to let itself catch itself and then I can take off again.
I am going crazy trying to figure this thing out. Other than that, the quad runs great. Parents bought bran new, just used around the property, 5000 miles on it. Any ideas???
By ATVNetwork
Why is it important to have an ATV Winch you may ask? If your ATV gets stuck in the mud, you can attach the winch cable or rope from your ATV winch to lets say a nearby tree, or something else that can act like a large anchor, to then pull yourself out. You can also help get your friend's ATV out of the mud if they get stuck, and be a hero! It's also a must have in the winter, if you have a plow...
An ATV winch is a must have accessory for most 4WD ATVs, especially if you plan on riding in areas where you may get stuck or need to help a buddy out of a pit. Sure an ATV tow rope might work for that, but it sure is nice to have a winch ready to go and provide that pulling power when needed. If you are debating a synthetic line vs steel cable, read up on the difference, pros, and cons of each. We have an article explaining some of this from a few years back here. Some 2WD utility quads can also make use of a winch. In most cases a 1500lb ATV winch is just fine. If you are moving up to some of the larger ATVs and UTVs and want more power, you can move up to a 2,000lb or 3,500lb winch, depends on what you want to spend really. There are a few good buys under $100 you can find on Amazon today, that will get you going. We wanted to showcase and share a few of these with you.
CASTOOL Electric Winch 12 V Recovery ATV/UTV Winch Kits Wire Remote Control 3000LBS Capacity
Easy Handling And Comfortable Use With Remote Control, Take-up And Release The Rope Automatically Prepared For Mounting Onto a Vehicle Building Boat ATV etc. Permanent Magnet Motor Draws Less Current, Idea For ATV Use 3000lb 12 V Winch With Reliable Engine incl. Overheat Shutoff Strong Steel Cable Compare Others 6000LBS , Mounting Kit And Plugs Plus Remote Inclusive Single-Stage Planetary Gear System For Fast Line Speed Automatic Load-Holding Brake For Maximum Safety,More Convenience And Secure Steel Cable and Hook Currently $98.99 on Amazon
ORCISH 12V 3500lb Electric Winch ATV UTV Synthetic Rope Winch Kits
Comes with 2PCS Remote Wireless Control +1 pair of gloves A good quality hook and 4-way roller fairlead 3 stage planetary gearing system Specially designed for ATV,Corrosion resistant Sealed low amperage permanent magnet motor Currently $99.90 on Amazon Get the steel cable version for $88.99
Offroad Boar 3500Lbs Electric Winch for ATV/UTV Boat (Stainless Steel)
Comes with a good quality hook and 4-way roller fairlead 3 stage planetary gearing system Specially designed for ATV Free spooling clutch for fast Steel Wire Rope payout Sealed low amperage permanent magnet motor Currently on Amazon for $88.90
Its also worth noting that ebay has a few ATV winches under $100 you can check out as well. Some of these are:
NOTE: The ORCISH is the same price on ebay as it is on Amazon
There was also a pretty good $100 rebate from Warn, but that ended in May. Be on the lookout for manufacturer rebates and search online for deals. If you see some good deals under $100, please post in our comments. 🤑
By davestrans
Hello I,ve seen there was discussion about CDI boxes what they was for example, but I was wondering if a CDI box off of an 2008 Polaris Outlaw 525 will work on my 05 Predator 500, it has the same plug in, thanks to anyone that could help
Similar Tagged Content
- 1 reply
- 6,892 views
- 12 replies
- 5,949 views
- 6 replies
- 1,961 views
- 13 replies
- 3,078 views
- 10 replies
- 2,155 views
Gallery Images
