I had a quick look at some parts diagrams and it doesn't appear to have a clutch. The three models I looked at were all belt drive. I also have the 2008 750 manual so looked in there and it looked like the same engine/trans setup, and it has no clutch. It seems the belt and pulleys are the only "clutch"..
I would suspect that the variable ratio system of the belt drive is playing up. That's the variable width belt pulleys I'm talking about. One of them is possibly moving apart at too lower revs, or one of them isn't moving apart when it should.
He should get a manual. They can be downloaded for free, from right here in quadcrazy quite likely..
It sounds like the drive (primary) clutch is getting hung up somehow and can't move properly. I've seen bits from a broken belt get into the sliding sheave bushing making this happen. You'd likely need the proper clutch puller to get it off to clean & inspect.
Thanks for the replies guys. We've gone through the clutches and everything looks okay and is in spec. I am pretty sure that his issue is that the bike is in "limp mode" from the belt failure switch. The problem with this is that the person he bought the bike from replaced 2 of the connectors that would be used to reset the belt failure and take the bike out of "limp mode" with trailer plugs that now can't be crossed over because the other connectors are the factory plugs. Can anyone tell me what wires are being crossed over when the plugs are switched during the reset process? I feel like I should be able to jump these out to get it out of "limp mode" to see if that's what is causing his issue. If that solves his problem we can look at getting the proper connectors. I've looked through the service manual but can't clearly figure out what is taking place during the reset, and I don't want to burn something up or make the problem worse.
Hi. I looked through the 650 manual and it didn't mention any Limp mode. It shows the switch as being connected to the wiring by two wires only. The manual is in the manuals section..
Is it still needing high revs to get moving, as you mention in your first post ? That doesn't really sound like Limp mode.. Those variable ratio belt drives can be quite temperamental.. They need everything just right on the front and rear pulleys, and the distance between pulleys, or they cause problems.
    • By carkivey3
    • By mmikesell
    • By EasyE
    • By opnea
      Recently picked up a 1991 Lt230e for repair. Compression is a little low Id say, around 80psi, I also have spark but the spark is odd . When cranking the spark is a constant arc. I’ve got it to sputter but never fully turn on. I believe the spark is my issue, being constant and not detonating at the right time. I’m not sure whether this issue is an electrical fault like some missing ground, a faulty cdi, or a timing issue. Any ideas where I should start?
