I had a quick look at some parts diagrams and it doesn't appear to have a clutch. The three models I looked at were all belt drive. I also have the 2008 750 manual so looked in there and it looked like the same engine/trans setup, and it has no clutch. It seems the belt and pulleys are the only "clutch"..
I would suspect that the variable ratio system of the belt drive is playing up. That's the variable width belt pulleys I'm talking about. One of them is possibly moving apart at too lower revs, or one of them isn't moving apart when it should.
He should get a manual. They can be downloaded for free, from right here in quadcrazy quite likely..
It sounds like the drive (primary) clutch is getting hung up somehow and can't move properly. I've seen bits from a broken belt get into the sliding sheave bushing making this happen. You'd likely need the proper clutch puller to get it off to clean & inspect.
Thanks for the replies guys. We've gone through the clutches and everything looks okay and is in spec. I am pretty sure that his issue is that the bike is in "limp mode" from the belt failure switch. The problem with this is that the person he bought the bike from replaced 2 of the connectors that would be used to reset the belt failure and take the bike out of "limp mode" with trailer plugs that now can't be crossed over because the other connectors are the factory plugs. Can anyone tell me what wires are being crossed over when the plugs are switched during the reset process? I feel like I should be able to jump these out to get it out of "limp mode" to see if that's what is causing his issue. If that solves his problem we can look at getting the proper connectors. I've looked through the service manual but can't clearly figure out what is taking place during the reset, and I don't want to burn something up or make the problem worse.
Hi. I looked through the 650 manual and it didn't mention any Limp mode. It shows the switch as being connected to the wiring by two wires only. The manual is in the manuals section..
Is it still needing high revs to get moving, as you mention in your first post ? That doesn't really sound like Limp mode.. Those variable ratio belt drives can be quite temperamental.. They need everything just right on the front and rear pulleys, and the distance between pulleys, or they cause problems.
  • 4 months later...
Just getting back to look at this issue now. My friend ended up pulling the bike apart further and decided to replace the full wiring harness as there was lots rigged up wiring on the bike and he wanted to make sure his issues weren't stemming from an electrical problem. We finally found a harness and got it installed last weekend and now have the bike back up and running. The issue is still there though with the rpms having to be quite high before the belt starts to engage and move the bike. With the electrical all back to stock, it is definitely in the converter system. Like I mentioned in my original post I'm not super familiar with this system and what should be taking place when he pushes on the throttle. We have the manual, which is great for assembly and disassembly, but lacks any explanation on how this is supposed to work and what I should be looking for to be taking place.  Any chance you could give me a bit of a rundown on what I should be seeing? Maybe some common issues that I could investigate? He's telling me that the throttle is almost 3/4 of the way before the belt is starting to engage. Is there a way to measure the RPM's or to know at what RPM the belt should be engaging?
We're trying to get his bike ready for hunting season this fall, so any help would be greatly appreciated.
The belt reset switch is under the belt cover just push it back if it has tripped. This video might help there are many things that need servicing including adding or removing shims for belt adjustment.
    • By fixitforfree
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
    • By exalrod
      Hello All !
      Could anyone help with this?
    • By jmeier1981
      Ok guys Ive got a few more for ya.
      TIRES:
      Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
      WHEELS:
      Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
      SNORKEL:
      I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
      Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
    • By jmeier1981
      Ok so I bought the 05 brute force and after putting about 60miles on it I have some concerns.
      The engine seems to run REALLY HOT, like almost burnning my legs through my jeans hot but no warning light comes on and it doesnt seem to "act" hot is this normal, does it have any saftey feature to prevent over heating or heat damage?
      It also seems to have a slight miss, or hesitation? When you slightly crack the throttle open and hold it at a steady RPM to give it a slightly higher idle it will run smooth for a couple seconds then miss and sometimes backfires. It also seems to sometimes have a hesitation if you jump on the throttle, what could cause this?
      Also a couple times when shifting from reverse to high it sounded like it got hung up in between and there was a slight squeal as if maybe the belt was slipping and there was also a slight burning plastic of rubber smell. The belt IS new and it doesnt feel as if it is slipping when accelerating and the belt light hasnt come on.
      Anyone have any suggestions?
      It does seem to run really well and HARD accept for the slight hesitation or cough and the occasional backfire, I ran it up to 69MPH with both me and a buddy of mine on it, combined weight of almost 500lbs
