By Eisenmatt17803
Good Morning!
Thanks in advance.
By jashadams
By McG75
Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds. It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
By jatho
Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
What were the design changes?
By Hermi
I have this ATV that was given to us by sister inlaw...and look like the fuel filter fell out when drive around....but i can find anything on that system. if anyone could be soo AWESOME to please post manual and/pr pick of where the fuel filer goes that would b GREAT!!!!
Thank you all for any help!!!!!!!!
