I didn't know they have a baby brother of the Rhino 660!
MSRP* $7,999 (Hunter Green) Available from October 2006
$7,999 (Red) Available from October 2006
$8,449 Hunter (Hardwoods HD Camo) Available from October 2006
Engine
Type 421cc liquid-/oil-cooled w/fan, SOHC four-stroke single
Bore x Stroke 84.5mm x 75mm
Compression Ratio 10:1
Carburetion Mikuni 33mm BSR
Ignition DC – CDI
Starting System Electric
Transmission Yamaha Ultramatic® V-Belt/H, L, N, R
Engine Braking All Wheel
Drive Train Yamaha On-Command® push button 3-way locking differential, 2WD, 4WD, locked 4WD; Shaft
Chassis
Suspension/Front Independent double wishbone, 7.3” travel w/5-way preload adjustment
Suspension/Rear Independent double wishbone, 7.3” travel w/5-way preload adjustment
Brakes/Front Dual hydraulic disc, twin pistons
Brakes/Rear Hydraulic disc, self-adjusting, shaft mounted
Tires/Front AT25x8-12 NHS
Tires/Rear AT25x10-12 NHS
Dimensions
L x W x H 113.6” x 54.5” x 73.0”
Wheelbase 75.2”
Turning Radius 153.5”
Ground Clearance 12.1"
Fuel Capacity 7.9 gal.
Dry Weight 1038 lb.
Bed Capacity 400 lb.
Towing Capacity 1212 lb.
Other
DC Outlet Standard
Instrumentation Fuel sight gauge, 4WD indicator lights
Lighting Dual 30W Krypton multireflector headlights & dual 21/5W brake light
Warranty 6 Month (Limited Factory Warranty)
More info at http://www.yamaha-motor.com/outdoor/products/modelspecs/441/0/specs.aspx
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
