arctic cat mudpro
Sorry i guess i should have posted all the info.
Arctic Cat 700 H1 Mud Pro ATV Engine: 695cc, EFI, SOHC 4-stroke, 4-valve, single-cylinder, liquid cooled engine
The “H” in H1 stands for Hemi. The hemispherical-shaped head creates more complete, more efficient combustion for performance-winning power
An Arctic Cat produced performance engine built in the state-of-the-art St. Cloud manufacturing facility
The potent H1 motor has led Team Arctic racers to two consecutive championships in the World Powersports Association (WPSA) Quad Terrain races.
Electronic Fuel Injection aids in perfect starting no matter what altitude or temperature changes.
Liquid cooling system with high-capacity radiator and thermostatically-controlled cooling fan provides consistent engine operating temperatures
The Duramatic Automatic Transmission has a long-life maintenance-free belt that withstands the harshest of conditions.
Arctic Cat 700 H1 MudPro ATV Chassis/Suspension: Machined Aluminum Wheels - All new 12” machined aluminum wheel design has an optimized scrub radius minimizing the rider steering effort.
Positive Shifting - A new shift detent profile in the lever linkage allows for improved positive shifting
Thundercat Halfshafts - Developed from the Quad Terrain Race circuit, all-new halfshafts (axles) were adopted from the Thundercat to increase durability and strength for the most brutal offroad conditions.
New Headlight Bulb Sockets - The right-hand headlight bulb sockets have been redesigned to eliminate the bulb popping out, decreasing the chance of the headlight housing filling with moisture.
Fully Independent Suspension (FIS) How it works with or without a swaybar - Arctic Cat ATVs have an optional sway bar available as an accessory purchase through your authorized dealer. Similar to any off-road 4x4 vehicle, eliminating the sway bar, lets the 10” of front or rear Fully Independent Suspension articulate through the full range of suspension travel. This increased articulation provides full tire contact in all types of off-camber terrain. The addition of the sway bar will impact the traction capabilities; however, it will enhance flatter cornering in aggressive trail riding
Arctic Cat 700 H1 Mud Pro ATV Snorkle
Industry Leading Ground Clearance - 14” of ground clearance enhances the ability to navigate through mud or over large rocks, logs, and other objects encountered in rough terrain
Large Capacity SpeedRacks - Industry leading weight capacity and overall cargo carrying surface area allows 100 lb carrying capacity on the front rack and 200 lbs. on the rear
SpeedRack Technology:
• Allows very quick installation and removal of a wide variety of Arctic Cat exclusive accessories without the need for tools, bloody knuckles or swearing
• SpeedRack and its accessories add value to the machine and also enhance the efficiency of your hunting, fishing, farming or utility chores
2-Inch Automotive Style Receiver Hitch - This feature allows the consumer to remove the hitch from their 2” automotive receiver and install it into the ATV’s receiver hitch
Floating Hydraulic Disc Brakes - Low maintenance, positive stopping power in either dry or wet conditions
Adjustable Shocks - Set the spring preload (5 rear positions, 5 front positions) on the shocks to tailor the ride to individual riding styles, terrains and loads
Electric Shift 2-to 4-Wheel Drive with new Electric Front Locking Differential - Full lock front differential transfers engine torque to both front wheels when selected for added traction with an all-new electronic rocker switch located on the gauge pod while 4wd/2wd switch is located on right-side handlebar for quick, convenient shifting in-and-out of four-wheel drive.
Additional 700 H1 MudPro ATV Features:
Highlifter's Outlaw MST Tire
Tires:
• The Outlaw MST is specially designed for riders who play in the mud but may not spend all their time there. 28-9.5x12(front) and 28-12x12(rear) offers the ultimate in all-around performance.
• With deep lugs, wraparound tread bars, and side sipes seen on tires designed for snow and ice, they offer the maximum in all around traction while delivering a smooth ride on hard pack.
M: Mud - The Outlaw MST is fully capable of handling the deepest mud holes. With one-inch tread depth across the face and shoulder, the MST is an excellent mud tire for the majority of mud riders.
S: Snow - The Outlaw MST is designed for traction in the snow. With significant sidewall wrap, the MST is excellent for grabbing snow and ice and plowing through even the deepest snow covered terrain.
T: Trail - The Outlaw MST is designed for a smooth ride on the trails. With a flattened tread profile with multiple sipes that create traction on both hard-pack and slick surfaces, the MST delivers a smoother, easier handling ride than most deep lug tires.
Color Options - Competition Green Metallic
very beast machine and i demand pics lol wen u get it.....man if i had the money... but i love my cat to much.. wat kind of atv u own??? all warn winches are water proof... to answer ur question lostcause
Right now i have a 650v twin arctic cat and my wife has a arctic cat 400. I just got the snorks done on hers last week. We are pretty much set up for long rides and go throw
what ever we come to. Heres what hers looks like
We do allot of river riding we are really lucky to have allot of privet ground to ride and the landowners ride with us some. Most of the trails have been around for 20 years or so.
Don't get me wrong we still have our trouble with kids riding in fields and trashing up things
but we try to pick up after them as best as we can.There is around 2000 acres close to us that our club is the only ones that can ride just because we take care of it and stay out of the guys crops. I just can't understand why when a guy says someone can ride people just can't stay out of his fields and ride the brush.
I've never understood the lack of respect for someone elses property either. If they're nice enough to let you ride the least you can do is follow the rules.
I have permission to ride several pieces of property and even though the owners never ask for help I always offer to help them build fence,feed,chase cows,etc. I figure it's the least I can to for their kindness! Most of them never take me up on the offer but a few have and I've always had a great time helping them! I LOVE to build fence and drink beer! Besides, you need a good utility quad for building fence so I get to ride and help a friend at the same time!
I feel strongly that if more people would do things to help and respect a few simple rules that we'de all have ALOT more places to ride.
    • By mga
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Werewolf
    • By Spritee1
      polaris 2008 50 outlaw automatic: got the 50 for free. would only run with chock on, replaced the carburator with new. I can't get the unit to an idle where the machine doesn't move forward. if I do get it to idle down within a few moments it will die. got something to try?
