Similar Topics
By quadcrazy
QUADCRAZY NEEDS YOU!
By Yourmanyoshi
I have a kawasaki klf 300b 1987 and when i got it originally from a friend it was sitting for like 10 years and of course it didn't run so i went through the steps of fixing it. Had good compression and clean carb but i wasnt getting any spark. I went through the steps of fixing that and turns out the cdi box was bad, so i replaced that and got spark so i started her up and she was a little scared at first but slowly broke in and idled perfectly fine. But everytime i gave it any gas it would just bog out completely so i had it idling and sprayed starter fluid into the intake to see if it would rev up, but it did the opposite and died out. I think it might be something to do with the spark since after that i took it out and it was wet. Im guessing its not sparking at higher rpms but i have no idea how to fix that since ive never had that issue before, keep in mind ive cleaned the carb maybe 5 different times with a supersonic cleaner and put needles through all the wholes. Someone please help me out with this old *** atv
By Ajmboy
This service manual is for a 1986-2006 Kawasaki Bayou 300.
Adding to downloads library.
By APExtreme1944
Hello all, I have a Kawasaki that will idle perfect but won’t go over 10 mph.
Reset limp mode, checked belt sensor, it will go into 4 wheel drive but won’t rev up more than 2500 rpm’s. I have no lights blinking.
Ran perfect for months until I let it idle while cutting limbs on the trails.
Had a new carb, air filter and gas, just won’t rev up.
Assistance would be appreciated..
tks
By oxidized_black
1981 - 2008 ATV HISTORY
1986 - 2006 Kawasaki KLF300 Bayou service manual
1988 - 2002 Kawasaki Bayou 220 service manual
1994 Kawasaki Bayou 220 Owner's Manual
1997 - 2002 Kawasaki Prairie 400 service manual
2003 - 2005 Kawasaki KLF250 Bayou service manual
2003 Kawasaki KVF360 Prairie service manual
2004 Kawasaki KFX700 V Force service manual
2004 Kawasaki KVF700 service manual
2005 Kawasaki KVF750 Brute Force service manual
2006 Kawasaki KFX80 Specs
2008 - 2009 Kawasaki KVF750 Parts Manual
2008 Kawasaki KFX450R service manual
2008 Kawasaki KVF750 Brute Force service manual
Please visit the downloads section at https://www.quadcrazy.com/files/
Similar Tagged Content
- 15 replies
- 11,906 views
- 0 comments
- 2,092 views
- 1 comment
- 1,908 views
- 0 comments
- 2,323 views
- 0 comments
- 2,311 views
Gallery Images
