yeah i need to run my breather lines for the diffs and the crank case still. Die electric? Add the grease?
ive got this anti corrosion spray im going to use. Its pretty much just like WD-40, but it does no go away/fade off.
Im not going to rejet for awhile.
It runs great, i havent noticed any problems.
Still pulls the front wheels off the ground.
I'll look into jetting it when i get a pipe, air filter and a power commander ready to be installed.
Im going to paint the snorkel black.
that will probably get done when i get my breather lines ran
die electric is a grease u put over u spark plug and electrical connections that stope the water from going in and messing up the electrical current... u put it on ur spark plug and ur can run it through anything and and their wont be the tinniest speck or sign of rust on it..
Yup
Its getting closer to becoming 100% trail ready.
Im pretty sure i toasted the heck out of my winch.
I'll dig into that mess sometime this week.
But my highest priority right now is to finish up my snorkel
next will be to die electric every electrical plug/ connection.
my winch, it re spools. but it has no torque at all.
As soon as the line gets tight. it just spins and spins.
I havent checked the "Spool- Free Spool" switch on the end.
Hopefully its not locked all the way.
but im really not sure.
i tried using it earlier this after noon when i was stuck deep in
a bottomless mud hole... Pretty sure i cooked er' though.
time for a 4k or 4500
bike is in my garage, i also have a car in there im working on.
I attached my winch line to the left front wheel of it, only thing i had
around that was solid and stayed put.
Started reelin in the winch line. Not a single problem.
It drug my bike across the garage floor with all 4 tires locked up.
Im not sure. But its one of those cheapie 2500lb winches.
I guess Warn use to own/make them.
im not sure what its deal is.
So wat problems u having is the winch just not having torque or its not lock so the spool can wind up the cable?
When i was stuck up to the top of my tires in the muckiest mud ever.
I went to winch out and the winch began to pull me and then stopped.
it was working, but it was reeling in any line.
Sounded like something in the winch was slipping or grinding.
Maybe my cable is slipping around the drum.
Im not sure how the cable is attached to the drum.
But lastnight i i pulled the bike across the garage floor by the winch and it acted fine.
Progress tonight-
got all my breather lines ran.
I was told there was 2 vent son the front diff.
i could only find 1. so im waiting to hear back from this guy i chat with.
I'll take some new pics.
i've got a 3" lift coming
a 2" power tip coming
Im wanting to build a stereo for it
I need to put a set of hand guards on it
I could use a new set of grips
a set of bar ends also.
Bigger winch
HMF pipe and K&N filter
Jet kit
need an ammo box or something similar
in size for my rear rack to keep my toe strap in.
thats about it..
im not 100% sure if im going to install the lift kit.
I may end up selling it and end up buying a 1-2" lift kit.
Im just a trail rider. Im not into those 100ft long mud pits or anything.
Yeah
im aware of the issues i may encounter.
the extra wear and tear on the cv axles, along with the ball joints.
yeah yeah, i know.
Im not 100% sure that im going ot keep the 3" lift.
i may buy a 1-2" lift.
It is installed though.
Along with the 2" exhaust tip.
The winch, 4500lbs is alot.
but my 2500lb winch let me down this past weekend.
and thats was not cool at all.
yea their is a guy on the highlifter forums that makes lift kits with axle spacer he is really friendly... and very well built lifts... from wat i heard he will help u through every little problem.. u would still have the same problem with 2" lift.. wat kind of lift did u get anyway?? and they sell 1" lifts??
I really need to make a new thread.
but here are some new pics
Left front measurement with no lift-
right front with lift-
Some nasty angles here.
Check this out!
So you see my CV axle angles.
Im thinking about pulling the 3" from the year and installing the 1-2" brackets in the rear.
No, i dont know of any 1" lifts.
the lift i went with is the one floating around on ebay.
a number of rincon guys suggested it.
So i took there advice, with not much to lose.
Well the same guy that sells the 3" kit, also sell's a
1-2" kit. thats not 1 and 2 inch, that 1 to 2 inch.
    • By cruteg8
    • By cruteg8
    • By sunn
      Any ideas?
    • By baller74
      Hi here's the other half of the awesome deal on a quad!
      grumbles when I went to look at this quad the seat was off and the headlight was laying aside the tank. first things I noticed  was the wiring or wires that were cut to the cdi box and the ignition switch also the seat was  off and the fuse off the battery was removed  next was the jumper  cables hooked up directly to the 110v house plug and the smell of burnt plastic and wire permitted the area. the guy selling it wasin a pinch and eeded quick cash so I overlooked my gut instinct and did a quick tally of cost and parts if I had tobuy the whole  electrical system  essentials to make it run again and slowly let the numbers 50 fly out and shut up. the foot crank was stripping bolt snapped  but I turned it over  good compression . this quad was clean as a whistle like brandnew  andthe harness so far is in excellent shape. I stopped at a friend's house and found a kymko cdi since box was actually the maker of this engine. fo free and began my next days adventures dreaming that the wind would be in my face and the cops at my back way behind me hauling as* round town In a couple hours I mean he said it ran just fine the day before ....
      well it's 715  this evening and I'm still trying to find a factory service manual that is free I can download at least the electrical schematis and conponant pinouts with wire color  and a troubleshoot guide with component testing procedures as there more than six wires for the cdi the leftovers are green green with yellow   babyblue and brown with yellow  no eof these are hooked up and she's a dead horse hoping someone could walk me threw them and there correct designation not just spliced I to a hit etc. the wires I hooked to the cdu are white pickup pin 1, blackwhite the pin 2, blackgreen ground pin 3  4 empty  2 plug  slot 1 empty slot 2 brownyellow power. now no been arguing with crapgpt all day sYs the 2 plug 6 wire ac cdi is the oem match for this one. now there was t a cdi when I bought it was "lost" probly along with the "KEY" but the cdi I pulled up shaws a 2 wire boobs 2pluh 6 pin cdi need to know if I can make her go with this cdi I looked at the wiring to that one And shows the stator hot and cold go to those extras  not sure but I am leaning towRd there's N internal voltage regulator built into that cdi box. anyone have the skinny on this I have  a voltage regulator 5 wire from another bike new bit has a pink wire when I put jumpers from my jeep to the battery and fused the hot side up  and tied the red and brown side on it switch no get nada but have voltage from battery to start solenoid  to the cdi hot pin the main harness connectors the headlights the green with yellow and  all the red wires read that brown with yellow is an accessory wire 12v switched used for engine control restrictions  but won't run without constant 12v if this is true I want it bypassed I. 205 pounds and little 200 is gonna struggle enough hauling me don't need any extra help there and infact if anyone can give me a few parts number to buy for some extra preformace and horsepower. I'm on a beer budget after my superchargered wrangler build so pheniox racing gurus and backwood tweeker brothers your input will be invaluable but you would add what you know. alright guy let er ripp I'm all ears.
    • By Arizona
