I prefer to do as much myself as possible, but I was uncomfortable removing the carb, so I decided to have a local shop install my Dynojet kit on my 08 AC 400.
The guy doing the install told me he didn't adjust the pilot screw (aka fuel mixture screw) because it required a special tool he didn't have.
He described it as round on one side and flat on the other. The Dynojet instructions say to adjust with a flat head screwdriver.
I called their tech line, and they seemed to think only Honda and Polaris used the D-shaped adjustment screw, but they're sending me a tool anyway.
Per my manual, the stock pilot screw setting is 1 3/4 turns out, and the Dynojet kit recommends 2 1/2 turns out.
If it's idling and running okay at lower throttle, will I be okay leaving the pilot screw at the factory setting, or should I go ahead and adjust to Dynojet recommendations?
Can I make the adjustment with the carb still on, or does it need to come off?
Edited by AC400TX
I agree with AJMBOY: I don't know much about ACs, but if you are piped then go with what Dynojet says- they do it for a living. Plus they have an 800 number you can call which helps a lot.
Edited by Raptor8
speling: computer's fault
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By en4cer
      Problem number 1,
      2000 Polaris Xplorer 400.  No start, has spark. Has fuel ,found Low Compression less than 60 psi.  What to do next?? Going crazy here.
      Problem number 2.
      1994 polaris Sportsman 400 starter won't engage.  Button on left side with  light switch seems to be almost stuck in, weak spring behind button?
      Any help would be nice.
      Thanks Chris in West Central Minnesota
    • By davefrombc
      1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
      View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
      This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
      Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
