By beast6228
So the other day I picked up a Lakota 300, it's going to be a new project for a bit, the engine is super clean and so is the frame...luckily the VIN was intact. However, it is the missing the air box (the one that holds the filter) but it does have the air chamber that goes to the carb. These air boxes seem to be pretty pricey, so my question is has anyone had any luck running a pod filter on theirs and if so, what kind of jets are you running? The carb on this one is a Keihin CVK, I have yet to pull it off and inspect it.
By akira gatewood sr.
Just bought 07 450ER and took it out for a ride(20 min) came back in and saw oil on swing arm. Upon further inspection found it was coming from air box. Wondering if it could be to much oil ( draining and refilling both tomorrow) , or possibly something worse. Guy isn't answering any questions now smh.. thanks ahead of time
By p5200
Hello, can someone please verify whether or not, this kit will fit my 2000 Honda trx ex300? Thanks! 🙂 Amazon.com: Air Filter, Oil Filter & Spark Plug Compatible for Honda Fourtrax 300 2x4 & 4x4 TRX300 / FW : Automotive
By twheelerk
Hello I have a 1981 Honda atc 200 I recently rebuilt starts first, second pull no problem, changes through the gears no problem but the only problem I am having is when I give it gas it pops an sounds like it is choking out. I picked up a carb for it seamed too help but still bogs alil when giving it throttle an loses some power…also I have too run this new carb on half choke, any advice would help thanks
