2002 Honda 400EX Problem
piebelly
I just recently bought a 400ex 440 bore, wisco pistons, and a hotcam in it. Quad runs great, however, it's hard to get started. It has the stock starter on it, brand new battery, and we have eliminated that the starter cylinoid is bad. It will however crank over with a battery charger that is on 12v Start Engine selection. Why is it doing this? It roll starts no problem. Do you need a hotter starter with the 440 bore? Need help asap. Thanks.
Since it's modified, it may take more cranking power to get it started. That is my guess since you said you put a new battery in it and it's difficult to turn over.
It does however turn over when hooked up to a 12V source.
Even though it is a new battery, it could be defective and not taking a full charge. You may want to have it tested at the place where you bought it.
I believe that atv takes a battery #YTX9-BS which is a Yuasa number if I'm not mistaken.
If it tests good, you could try finding the same group size battery but with more CCA. (Cold Cranking Amps)
Have a look at these Honda batteries, notice the CCA: Honda ATV batteries
You may also want to doublecheck your charging system..as a second possibility..
"The Honda TRX400EX uses a full wave permanent magnet type of charging system. To test the charging system the battery must be fully charged. To accurately check the charging system and its components you will need a digital multimeter. A set of alligator clips for the meter leads will make some jobs much easier.
To test the charging system as a whole, leave the multimeter set to VDC, touch the red meter lead to the positive post of the battery and the black meter lead to the negative post. Start the engine with the meter leads still connected to the battery posts. Rev the engine up to approximately 4,000 rpm and compare your reading with specification.
(Specification for battery charging voltage with the engine at 4,000 rpm is 13 to 15.5 VDC)
If battery charging voltage does not reach 13 VDC, the charging system is not working and the components must be checked.
If the battery charging voltage goes over 15.5 VDC, the regulator is defective and the regulator/rectifier must be replaced."
Edited by ATVmechanic
  • 11 months later...
because you increased the compression on it but when you put in the hotcam you had to take out the compression release out so the hot cam could work properly to gain p0erformance that is something youll have to deal with mine does it also more in colder weather in warmer weather youn wont notice it.
Opie, did you notice that this thread is a year old? This poster has not logged on since last February. I am curious however about the fact that you have to remove the compression release with the Hotcam on the 400EX. My friend put a stage 1 Hotcam in his 450R, and it worked with the compression release. I wonder why they would not make the EX cams compatable with the compression release?
    • By McG75
      Sorry I suck at these forums so if you see this submitted under update status, my bad. Anyhow this is a new shock for a 96 Yamaha Kodiak 400 4x4 it fits my 96 Yamaha Timberwolf 250 4x4 perfectly. Little narrower are the bottom than the original but everything else is perfect. I extended it to almost a half in from full extension because I’m pushing 350 pounds.  It rides and hold me well. So if any of y'allRace driven shock. have been looking for one and didn’t want to do the research here it is.
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By hardcastle
    • By Its-always-something
