A husband and wife love to golf together, but neither of them are playing
like they want to, so they decide to take private lessons. The husband has
his lesson first. After the pro sees his swing, he says, "No, no, no, you're
gripping the club way too hard!"
"Well, what should I do?", asks the man.
"Hold the club gently," the pro replied, "just like you'd hold your wife's
breast."
Taking the advice, he takes a swing, and POW! He hits the ball 250 yards
straight up the fairway. The estatic man goes back to his wife with the good
news, and the wife can't wait for her lesson.
The next day the wife goes for her lesson. The pro watches her swing and
says, "No, no, no, you're gripping the club way too hard."
"What can I do?" asks the wife.
"Hold the club gently, just like you'd hold your husband's pe***."
The wife listens carefully to the pro's advice, takes a swing, and THUMP --
the ball skips down the fairway about 15 feet.
"You know, that was a lot better than I expected," the pro says. "Now, take
the club out of your mouth and hold it in your hands..."
  • 4 years later...
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Frank Angerano
