Last time i rode, the ATV park was mud infested, and i mean, the roads, trails and everything. it was a slop, i power washed after( TRIED lol ) i have this hard clay on the tires, that is just a pain in the as* to try to get off, is there any spray or anything that can eat away at this? i think it's clay-ish mud? its light brown, tan. i can take pictures if needed, it's not to much it just makes me angry.
i use the pressure washer with the highest pressure nozzle and it cleans it great. makes it look black again. if that doesnt work then go to walmart and go to the tire spray with dale earnhardt on the can. sorry but i cant think of the name of the stuff. we used that on our tires when our pressure washer was dead and it also worked great.
that kinda slop is usual in georgia.
Pull it out BEFORE the snow melts!!! driving in the snow cleans just as well as a presure washer and is the only thing that will get the mud off your tires PLUS its WAY more fun!!!
well i live in a city like place, i dont really have a field or anything to ride it around in
WD-40 works good for before, as does cooking spray.....afterwards you can use Purple Power or if you wanna spend the extra money Simple Green...
Just make sure when you're spraying WD-40 or anything like it you don't get it on your seat...that'd make for a slick ride
:elvis::mad::laugh::confused::yes::wink:
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By Adamb2025
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
