Which quad should I get?
By huntindog
TIA
By Mech
View File 2022 Texron Tracker Off Road EViS service manual
2022 Texron Tracker Off Road EViS Service Manual with wiring diagrams.
Submitter Mech Submitted 11/30/2023 Category Textron Off Road UTV
By Jhb12686
Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
By mkibbe
My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
Similar Tagged Forum Content
- 0 replies
- 2,457 views
- 1 reply
- 2,494 views
1989 Harley-Davidson Custom - STREET LEGAL 4 Wheeler
By h1000101b,
- harley davidson
- custom
- (and 14 more)
- 4 replies
- 4,197 views
- 0 replies
- 1,959 views
- 13 replies
- 23,504 views
