its a 2000 AC 90
it runs, but when ever I hit the throttle it just dies. The compression is good, i drained the carb....still nothing. Runs perfect, then any throttle will kill it. Any help will be well appreciated, thanks in advance!
Jets could be clogged, how's the air filter? Did you get a bunch of snow in your airbox, have it melt and suck water?
maybe, but wouldnt that cause hydro lock and it wouldnt run at all?
ill take apart the carb sometime next week
you think compression could have anything to do with it, or maybe a seal or piston ring? It was at WOT for like 2 minutes straight lol...i kinda beat the hell out of it.
Compression could be an issue for sure, do a test. Also check the timing. If you have a service manual, it should tell you how to check the ignition components with a digital multimeter. If every thing looks ok with those, check valve clearances and the timing chain.
I would rip the carb out like you said you were going to do, and a compression test like DirtDemon said. I'm leaning towards a carb issue. By a rebuild kit from the dealer.
update
Its been sitting for about 3 weeks....never touched. Started and drove fine? I have no Idea what was up, but it works now so w/e haha. Thanks for the help guys....Ill probably need to strip down that carb sometime.
Really? Should I do anything before running it again?
Wonder how that happened? I had the thing buried in the snow, but im not sure how it could have gotten in to the carb or gas tank.
You also could have gotten a little water behind the stator cover. If you have the same problem again in the future, check the secondary ignition system. Ignition components work fine one minute and can go completely dead the next.
    • By Elk
      2002 Polaris Magnum 325
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
    • By 97kingquad
    • By xxjeanxx30
      so i have bought a quad (1985 suzuki LT250E) and the quad had the wrong spark plug and was not tight enough I now have dirty tread and a compression leak what would be my best option try to force the spark plug or take a tap and clean the tread ?
    • By DZL1
      Thanks in advance.
