      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By qcm413
      Hi,
      thank in advance
    • By Matman
      Scrub brushes didn't work.
      Pressure washer was able to remove the high spots and leave a nice consistent orange.
      Sent the cylinder out for a new sleeve and it came back shotblasted clean.
      Wire brush and elbow grease does the best so far, now using drill attachment with wire brush.
      What else besides scotch brite pads and detergent is out there?
    • By Brian Anderson
      Help guys PLEASE I have an artic cat 700 mud pro 2012. I was riding it the other day and it started skipping after i shut if off that day it was the last time it would crank. it was showing codes 12 and 13 then disappeared and THEN EFI on the dash but now it's not showing. it will turn over but it will not crank. it's not getting spark either I dont believe
