By rjsummer
By LMI
By sandman001
By fixitforfree
By killerklown
Regarding a 1988 Moto 4 200. I see there is a brake switch behind the left brake lever on handlebars, but only a single filament bulb in the taillight. Do these have brake lights or just taillight?
