By hengstserepair
Nuetral: Runs as expected
Lorne
By sandman001
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By Rockbottom
any ideas how to correct
By digrig
Hey everyone,
