Hey guys i have found a 1997 polaris xplorer for $450..it needs a few things...one of which i do not know anything about it is a cdi box, it need a new one... does anyone recommend a certain brand? or were i can find a stock one.. i have been searching on google for sometime now and no luck... i need your help
If you want to go with an aftermarket unit, I would recommend MSD if they have on for that quad. Otherwise I would go with the OEM unit, Service motorsports has excellent prices on OEM parts.
Either get MSD or OEM like the man said. The only other kind is the Dyantech, most aftermarket companies use this one with there sticker on it. The Big Gun Rev Box is a Dynatech CDI, just telling you that so you know what the dynatechs look like. They have about a 25% fail rate.(at least in the UTV world)
MSD is the best, if you look at almost any race car you see, it will most likely have an MSD ignition system. They make systems for some atv's but it is likely that your Polaris is not one of them. It is worth finding out though. Either way the CDI should be pretty easy to install. Sorry, actually it is servicehonda.com, they sell parts for all types of machines though not just honda.
Service Honda Home of the CR500AF 500AF 500AFX Junior-X - Honda Motorcycle Parts
Edited by DirtDemon
Create an account
Register a new account
Sign in
Sign In Now
    • By Malta54
      I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
      Sparking Plug
      Fuel Injector
      Fuel Pump
      Fuel Filter
      Fuel Valve
      Fuel lines
      Power Control Module
      The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
      The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
      Would greatly appreciate any assistance.
      Thanks in advance.
    • By Bobbles
      Hi all, new to here, looks like a great site. Own two atvs, an at the moment not working honda fourtrax and a yamaha moto4 of some description, trying to work out what model yammy it is.
    • By mav0016
      Hey does anyone here know where I can find another brand oil filter for the stock argo filter? Being so new its hard to find anything. Thanks
    • By Zachary
      Hey guys I have a 99 xpress 300 and I'm having an issue, I rebuilt the engine and it will only start when I put my han over the intake on the car (when I manually choke it), I am not very familiar with plunger chokes.could some one help me understand how this choke is supposed to work and maybe how to ajust it so it works, thanks!
    • By USRaider
      Hello all!
      Kept indoors but hasn't been run in 5 years.  We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
      I'm optimistic!  See y'all around!
