By p5200
The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
By Bobbywolf
Thanks for any assistance.
By p5200
By Gwbarm
By huntindog
TIA
Similar Tagged Forum Content
