I had a small sapling / tree get between my brush guard and the fender flexing the fender so it broke the headlight attachment point from the fender. Any suggestion on how to repair? What kind of plastic is the fender made from for gluing? I need help in fixing this problem correctly.
Yes, please post the year make and model of the atv. Harbor Freight tools carries plastic welders for pretty cheap, it would work much better than trying to glue it back on. I would recommend one of the units that use compressed air, they get better penetration than a hot iron alone. There are better types out there but they are much more expensive.
Harbor Freight Tools
Edited by DirtDemon
What you recommended is exactly what I was thinking. How am I going to find out the type of plastic they use on the fenders? Do you have any experience on these type of fenders? Not specifically welding the attachments back on for the headlights but anything one the plastic fenders / body parts. I feel this would be the best fix but I want as much information as I can get before I start any repair. I hate doing things twice.
Most ATV fenders are made out of polyethylene or PE. It is an oily plastic and fuses easily with heat, so they should weld well. There are usually three different types of PE, high, medium, and low density. I would think that atv fenders are probably low density, but they might be medium. Either way, you can weld them together, we fuse high density to medium density all the time at work, you just have to put the heat on the hd side for a bit longer than the md side. Plastic welding with a hot air machine is done like gas or TIG welding where you have your heat source in one hand and your filler material in the other. The idea is to heat the surface of the work area to a molten state without pushing a hole all the way through the material, then you add the filler material to the heated puddle and melt, or "wash" it in with the heat source. Like any type of welding, practice makes perfect. I would try welding on a similar material to practice before you take it to your quad.
Thanks for the info. I was checking other sites and you confirmed what they all said. Except you explained it better. Going to Harbor Freight Tuesday to get the plastic welder. I also tore off the plastic skid plate at the Hatfield McCoy trails in July and the welder will be the only way to properly fix it.
Great explanation DD!
    • By Yamahahahaha
    • By quadnut20
      What does everybody carry to fix tires on trails ? Looking for suggestions on Kits to buy !!
    • By oxidized_black
      1985 - 1990 Suzuki LT230 & LT250 service manual
      https://www.quadcrazy.com/files/file/532-1985-90-suzuki-quadrunner-lt230-service-manual/
      1987 - 1998 Suzuki Quad Runner 250 & King Quad 280 service manual
      https://www.quadcrazy.com/files/file/268-quad-runner-250-king-quad-1987-1998-service-manual/
      1987 - 2006 Suzuki LT80 service manual
      https://www.quadcrazy.com/files/file/89-1987-2006-suzuki-lt80-service-manual/
      1987 Suzuki LT500R Quadzilla service manual
      1988 - 1992 Suzuki LT250R Porting Instruction
      https://www.quadcrazy.com/files/file/90-1988-1992-suzuki-lt250r-porting-instructions-manual/
      1988 - 1992 Suzuki LT250R Quadracer service manual
      https://www.quadcrazy.com/files/file/91-1988-1992-suzuki-lt250r-quadracer-service-manual/
      1988 - 1992 Suzuki LT250R Tuning Guide Instruction
      https://www.quadcrazy.com/files/file/92-1988-1992-suzuki-lt250r-tuning-guide-instructions/
      1999 - 2004 Suzuki King Quad 300 service manual
      2002 - 2007 Suzuki 500LTA service manual
      2002 - 2009 Suzuki LTF250 Ozark service manual
      https://www.quadcrazy.com/files/file/94-2002-2009-suzuki-ltf250-ozark-service-manual/
      2003 Suzuki LTZ400 service manual
      2006 Suzuki 50LTZ Quad Sport service manual
      2004 Suzuki 250LTZ Quad Sport service manual
      2005 Suzuki LTA700 King Quad service manual
      2007 Suzuki 90LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/97-2007-suzuki-90ltz-quadsport-service-manualpdf/
      2008 Suzuki 400FLTF King Quad service manual
      https://www.quadcrazy.com/files/file/98-2008-suzuki-400fltf-kingquad-service-manual/
      2008 Suzuki 750 King Quad service manual
      https://www.quadcrazy.com/files/file/99-2008-suzuki-750-kingquad-service-manual/
      2009 Suzuki 400LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/100-2009-suzuki-400ltz-quadsport-service-manual/
      ALSO CHECK SUZUKI ATV SERVICE MANUAL DOWNLOADS
      Please visit the downloads section for ATV manuals at https://www.quadcrazy.com/files/
      Also available at:
    • By oxidized_black
      Yamaha ATV manuals are located in the downloads section here at QUADCRAZY.
      Please visit the downloads section at https://www.quadcrazy.com/files/
      Clymer ATV Manual - Yamaha Raptor 700R
    • By roggers
      Hi everyone,
       I often work on both ATVs and larger construction equipment, and I’m always on the hunt for solid OEM manuals—service, repair, and parts. The usual searches give a lot of random PDFs or unofficial scans that aren’t very trustworthy.
      What online sources do you all use when you need a factory manual quickly? Are there sites you’ve found that consistently provide genuine OEM content for ATVs or heavy machinery?
      I recently came across Heavy Equipment Manual, which claims to provide verified OEM service and parts manuals (covering brands like Caterpillar, Komatsu, Kubota, etc.). Has anyone here tried it, or do you have other go-to resources you’d recommend?
      I’m interested in options that are:
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
      Thanks for sharing your experiences and any recommendations!
