newbee & 94/400-WUZZ UP
rusobr2
i just traded out a garden tractor for this 400 atv ,lady has not rode it since last march, and could not get it to idle down to put it in gear, i talked to my atv wannabe specialist, he says no big deal,we can fix it.that was two weeks ago. so far i have drained the tank,and cleaned.w/new gas it will only start w/full choke or 1/2 choke,no matter how cold the motor is,or how warm it is. took the carb apart, and cleaned it good,blew out all openings, and checked the floats to make sure they were riding good. back together. started it and same problem,had my son hold the engine speed as even as possible. i sprayed carb cleaner around carb,and found that by the oil inj. fitn. it seemed to rev higher,tried to just barly snug this 10mm fitting and it seemed like it wanted to slip around,tried to loosen , and that worked just fine, but when i try to sung it, it seems to slip,could this be my big problem, and is there an easy fix or buy a new reed body, thanks,rusobr2 ( steven )
Please provide the make and model of the machine, I am assuming it is a Polaris two stroke. It definately sounds like an air leak. This will cause the high idle because you are getting too much air. It will also cause hard starting because you are sucking air in through the leaky fitting, which reduces the draw through the carb and thus it has a harder time pulling fuel up through the jets. Also, something that is commonly overlooked when cleaning a carb is the float bowl vent. It is a long thin brass tube that protrudes upward into the top of the float bowl above the fuel level and vents through the bottom of the float bowl. Make sure that vent is clean, blowing compressed air through the holes should make sure it is clear.
really !! i do appreciate the help- the idle problem -is that it won't idle,and if i try to set the carb cable high enough to make it run,so i can try to figure it out,it will only run high for about a 1/2 minute then it wants to die.so then i choke it a little to get it going again ,and once again try to figure it out .when i spray:no: a little carb cleaner around the oil banjo fitting it seems like it wants to run higher, but i can't find anything wrong with this fitting,tomorrow i will check the vent tube in bowl that you referred to. thanks,steven
Once again, please post the MAKE and MODEL of your atv, it will help us greatly to know exactly what you have. Check your float adjustment too, it sounds like you may be running the float bowl out of fuel. Make sure the tank vent is not blocked off. Also, you have dry stator(not surrounded by oil) then try spraying the carb cleaner around the crank seal there. Once again, an air leak can cause the draw through the carb to be insufficient to pull enough fuel through the jets, causing the bike have idle problems.
Edited by DirtDemon
I had a very similar problem on a 250 2 stroke polaris. Polaris puts drain plugs in the case at the bottom. Turns out on mine either someone had taken it out or it fell out. This put a straight hole right into the case. It gathered oil at the front of the engine on the frame as well and would only run on choke. Put in a new plug and seal for about 4 bucks and it ran perfect. Worth a look.
:yes::yes::yes::yes:FELLAS!! FELLAS!!-i now have the 94 polaris repaired--WA-HOOOOOOOOOOOOOO-i had a close friend come over after i was at my wits ends-he asked what all i have done. i explained to him all of the suggestions that i had received from this board. he started it and checked the carb-i told him i already cleaned the carb(to the best of my ability)he said it dos'nt seem like the LOW SPEED JET is open,i kinda scratched my head , and told him i think i cleaned everything-when he got it apart,he said he needed a small screw driver to get the jet out,so i handed him the one i used,he said smaller.so i went to my grinder and made it smaller-i didn't know this jet was in there-pulled it out and used my smallest tip cleaner from my torch--poked a hole in it and it fired right up,and set their an idoled, i just about pooped my knickers,he says jeeeeez man you already did everything else, and i'm not gonna charge you for poking one little hole.FELLAS, i was just about ready to pull the spark plug out and hang on to it ,so when i got me a new ATV at least i'd have a new plug for it. in this case its the little things that count-MANY THANKS to all ,and the support,damn thing sure is fun,thanks again,steven
    • By HSTAR
    • By John Sinclair
    • By rgeiser
    • By mehim
      Hi everyone.
    • By N00bie
