I have the same problem on my 2003 WARRIOR, working on it right now... It runs OK on idle but as soon as I give it a little trottel it missfire badly..
Checked the carb/inlet and new spark plug. The spark is a little weak...
Did you take the carb apart and clean it? Has it been sitting for a while? Have you tried a new spark plug? You may want to test the ignition components, stator, coil, cdi, and check to make sure you have a good connection between the coil wire and plug boot.
I had that same problem, its a dead man switch! I had to replace my switch after i rolled my 2003 Warrior 350. 42$ later it fixed the problem. I was thinking it was a clogged jet, but had my wifes dad look at he (an atv and car mechanic) if you take the top switch on the left side of the handle bar, cut it and uncross the wires it will run fine. If you have it running fine, for craps and giggles, apply your parking brake and then try and hit the throttle, it does the same thing! It prevents you from riding the quad under those circumstances. Like I said before mine did the same thing, the motor sounds like it cuts out constantly, but never dies, idles fine all day but just doesn't run like it should.
    • By RGS
    • By Kawasakibayounospark
    • By DPDISXR4Ti
      Thanks...
