I just rode my klf 300 all day yesterday, and today when i went to unload it it would not start. When i took the plug out to check for spark it only produced a very faint weak looking spark and it was not consistant with rolling over, is this from a bad ignition coil or could it just be a loose conection somewhere?
Definately check wires, connections, grounds and test ignition components like Bot said. Make sure that the spark plug boot has a good connection to the coil wire. Also check to see that your flywheel key hasn't sheared off, that will cause inconsistent spark that is out of time.
BTW, I think this thread may be better placed in the Kawasaki forum.
  • 14 years later...
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
    • By Brent Wright
