drill a hole almost as big as the studs with a left handed drill bit and that usually grabs it before it actually drills a hole and if that doesn't take em out then you have a hole to stick a screw extractor into to take them out if that still doesn't work just drill it out with the closest tolerance you can a run a tap through it to clean up the metal shavings and threads and get new studs make sure you get the hole in the center otherwise you got other problems
Exactly...use an "easy out" extractor.
Soak the siezed bolts with some penetrating lubricant, I prefer PB Blaster. Drill the hole in the stud like already mentioned, you want the hole just big enough that the easyout wont just tear through the outsides of the stud. Before you actually try to use the extractor, hit the stud sharply with a hammer, this will help shock the stud loose from the threads.
I believe you mean cylinder, unless this it an actuall big-bore cylinder, you won't even notice a power increase from a routine .5mm or 1mm bore increase. But, you won't have to worry about getting the old broken stud out anymore.
    • By DaleJAM
    • Guest
      By Guest
      I have a 2022/23 Honda Rubicon, and was wondering if there is an exhaust deflector available.  I have a rear basket w/ chainsaw mounts, a winch on the rear, and a hitch.  When I am working at the rear of the quad, the exhaust puffs and hits us, while we work.  It is quite annoying and wound like to be able to direct the exhaust downward.  Is there anything that you know of that would work w/o creating any back pressure that might disrupt the engine?  I’ve been searching for something like this, but can only find ones for small engines and silencers that would interfere with the winch.
      dave
    • By motox88
    • By tater
      Hey all, I have a new to me RSX850i that has a lot of exhaust smell in the cab and seems overly loud. I did check the pipes to the can and they seem tight, but you can't see much as they have a heat shield on them. Looking online these machines are loud in the cab to start with, but not too many posts regarding broken pipes and or exhaust smell in cab.
