SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve.
DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves.
Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs.
More info on SOHC Engines Vs. DOHC Engines
DOHC- dual over head cam, has 2 cams, one runs the intake valves and the other one runs the exhaust valves. the only disadvantage to dohc is the cost if you ever decide to put bigger cams in, you would have to buy 2 of them
SOHC- single over head cam, one cam has both intake and exhaust lobes on it
DOHC = Dual Over Head Cam
SOHC = Single Over Head Cam
Basically one camshaft or two camshafts in the head. Usually DOHC motors have 4 valves per cylinder vs 2 valves in a SOHC (2 exhaust and 2 intake vs 1 and 1)
Most, but not all SOHC motors are 2 valve enginges. For example, Honda uses a SOHC head with 4 valves on some of thier machines. Each intake valve is directly actuated by it's own lobe in the cam and the exhuast side uses a two fingered roller rocker arm to actuate the 2 valves on that side. This way you get the benefit of 4 valves per cylinder without all the extra moving parts. Many three valve motors use a two fingered rocker arm to actuate 2 valves off one cam lobe. The only real downside is that it puts more pressure on the cam lobe when it has to lift 2 valves instead of one, which causes the lobe to wear down faster. That is why it is best to use a roller rocker like Honda does to reduce friction.
Edited by DirtDemon
    • By kiriyaaoi
    • By Dgafchikk
      Whats the difference in the red honda atc engine and the black honda atc engine?
    • By garysaul
      Rear brake pedals very soft,I think all of a sudden as the kids have been riding this one.
      Changed pads-calipers in great shape
      Bled brakes--no change--apparently need new master cylinder?
      Never had any type of vehicle where the master cylinder actually failed
      Partzilla-$144---amazon $25 --has anyone used a chinese one
    • By Charlesawest936
      Hey guys iv kinda gotten myself into a pickle here and hopefully someone that really knows about these kodiaks will chim in please. Anyways whats going on is iv got a Kodiak 450 that was stuck in gear when i bought the bike. Stuck in gear meaning that the transmission was locked up. The motor still ran good it just wouldnt move. So i pulled the engine and split the case and found that 3 gears had teeth broken off of them. And might i add, the metal that these gears are made of is complete trash! Well at least the metal that my original gears are made of are but the gear-set that i ordered the metal looks to be made of a completely different material. Not sure if this is the correct word for it but i wanna say "Pot metal" is what im thinking iv heard that be called before it has like air bubbles throughout the whole thing it looks like. Anyways my issue is that the gearset that i ordered looks almost identical all except 2 of the gears the ones that the chain goes on which drives the output shaft that runs the middle drive gear so i found a chain thats supposed to be for a kodiak 400 since those are what gears i bought that didnt come with the chain. I was just assuming that the good chain that i had was going to fit the new gears. Does anyone know anything about the transmissions in these bikes that wouldnt mind helping me out? The 400 chain should be here in the next couple days when i get it ill let yall know if it ended up fitting the gears i have or not
    • By Viking
      There's an electrical cable connected to the front brake lever. The parts list calls it the front stop switch assembly. There is no stop switch on this side of the handle bars. Seems to be activated by the brake lever. Anybody know what it does?
