The centrifical clutch cover on my 1996 xplorer 400 4x4 has been vibrating alot lately an now the clutch housing inside has been rubbing the cover while idling. I took the cover off an its not cracked an the belt will need to be replaced soon but still very useable. If i manually pull the housing out away from the engine while it runs it doesnt rub but if i let it go on its own it rubs. Is there a bracket behind the whole case on the motor that maybe wore or the rubber gasket inside the housing spueezed too much over time that the cover is now too close?
My father-in-laws was the same way he has a polaris scrambler 500 and we just replaced the cover from ebay. I think is what happens is that it was once heated and heat will shrink the housing so that is the knowledge that i had found please let me know how u make out.
    • By HoldenBoy
    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
    • By davefrombc
      1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
      View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
      This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
      Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
    • By en4cer
      I have a 2000 Polaris 400 xpress with a no start situation,  I have spark and fuel.  Wont start on starting fluid.
      New fuel filter and spark plug. Did run prior on full choke.  Then died and not start since. I feel dumb ,  any body have a clue???
    • By quadnut20
