  • Join Today, It's Simple and FREE!
mkaskine
Will an '07 Raptor 350 axle fit '07 YFZ 450
Hello,
Can someone say what are the differencies between 350 raptop ( year 07 ) and YFZ 450 ( year 07 ) rear axles?
I have new g-force adjustable rear axle and just thinking is it possible to install it to YFZ 450?
Does that need some modifications or should it fit on it ??
Share this post
Link to post
The swingarms on those two machines could not be more different. I am quite sure that it would not work, nor do I think any Warrior or Raptor 350 part would be an upgrade for a YFZ, aftermarket or not. If you don't have a Raptor or Warrior to put the axle on, I would sell it and buy an axle made for the YFZ.
BTW, I changed the thread title.
Edited by DirtDemon
Share this post
Link to post
  • Similar Topics
    • By Kevin Nicoll
      Anyone familiar with these models? Its a new to me quad, picked it up for basically nothing... Just time and materials now, this looks expensive.
    • By Sharon van den Berg
      We bought an old atv from friends to bum around on the farm with. VIN number is rusted off. Is there a way to determine the year model from the engine number? We only need the info to buy parts. Please help
      As a manufacturer of CV axles for ATVs, UTVs and side-by-sides, TrakMotive has announced the release of 42 new part numbers covering 486 fitment applications for 205 models from Arctic Cat, Can-Am, Kymco, Polaris and Yamaha. Available in both OE replacement and heavy-duty versions, these axles are now in stock and ready to ship. TrakMotive says it is committed to offering the largest selection of CV axles in the industry while bringing new applications to the market.
      TrakMotive CV Axles for ATVs, UTVs and side-by-sides exceed OEM quality in fit, form and function, come fully assembled with all necessary hardware included for easy installation with no modifications required and include a one-year limited warranty, according to the company.
      TrakMotive CV Axles are available from authorized TrakMotive dealers and distributors. To contact TrakMotive, visit trakmotive.com or call 800-567-1608.
      https://www.autopartsforum.com/topic/92-trakmotive-introduces-42-new-cv-axles-for-atvutv-applications/
    • By Alois Specht
      Hi there , have a KAZUMA 500 JAGUAR the rear diff is permanently locked , how can I get it out of lock just about tried everything I think, ?? .  Thank you your help is appreciated.
    • By caperwing
      The rear brakes on this are hydraulic and manual. The hydraulic part is all messed up so I disconnected it all and want to go just manual on the rear. I got it all put back together but doesn't seem to work to well, like not enough pressure. The manual says I should mark the casing before taking it apart which I didn't read until to late. Any ideas? I put new brake pads on.
  • Similar Tagged Content
    • By Colin James Krepela
      So here's the deal people, I have an old Avenger 350 4X4 Shaft Driven ATV. They only made them in the early 80's their thought of as the first four wheelers from around back when Suzuki made one in 1982. I believe the engine on it is a Kohler as I watched this video https://www.bing.com/videos/search?q=avenger+400+atv&view=detail&mid=1E10E939019CA07770031E10E939019CA0777003&FORM=VIRE but mine is a 350. That's if its original, and it all looks original. I am wondering where I can get parts for this engine, or really what engine is it. I have no way to find the year, unless you guys know where a serial number might be. Every sticker is worn off. IF anyone has any information at all on these old wheelers it would be greatly appreciated. I specifically need the gaskets for the carb, and don't tell me I could build them please I want to restore it as perfectly as I can. I can take pictures of the wheeler/carb if it'll help. Let me know.
    • By oleskool
      Has new top end, piston, rings, valves, etc. great compression, good spark, plenty of fuel. Valves have been set. timing has been tripled checked. Can not get it to start. any ideas suggestions on anything I am missing. Also if anyone has the service manual it would be greatly appreciated.
    • By Martin Carrière
      Recently bought my BB. Everything works great. Only thing is, each time I put it in reverse, it either starts to rev high and start moving without giving it gas or I'll give it a bit of gas and let go and it will still rev at the same rpm or higher and keep moving. Doesn't do it for high or low.
