i just purchased an 08 i like it alot in the power department but the handle takes some getting used to. anybody else have 1 and know of stuff i need to look out for? also what sand tires/rim combo would you guys go with for the 700? thanks in advance.
john
That is exactly what you want. The straight paddles are more for off the line acceleration and the angled ones, like the sand star is more for carving bowls and such.
They are one of the best sand tires available. Skat trak makes some great one too.
the only problem i'm having is finding a rear rim for the quad. like you posted about the 11 inch rear stock so i'm looking for a 12x8 rear or something because itp has 22x11-12 rear sand stars but even the itp website only has 10s. i have no idea where to buy parts online.
You also want to make sure you get a wheel with the correct offset. The IRS quads use a rear wheel with alot of back spacing, so it has a drastic positive offset. If you buy normal rims, your machine may be close to a foot wider. Not only would that be a nuisance in tight spaces, the suspension will turn mushy and the handling may get wierd.
Itp made rims specificly for the 700xx!!!!!!!!!!!:aargh::aargh::aargh::aargh:
no need to yell. i cant find those anywhere not even on itp's website. douglas is coming out with some i ordered those since my local honda superstore couldnt find the itp's either lol its a pain in my a$$.
Try rocky mountain atv...and don't get the sand star's - molded tires suck.
Get the angle paddle skat traks.
So what makes these tires suck? I know plenty of people that run them and that are extremely happy with them.
If you are going to try and steer someone away from a product, why not supply some helpful info on why he shouldn't run them. THEY SUCK makes you sound like a little kid trying to do a review.
I could have used "stupid" but we'll get to that later.
They suck because they are heavy compared to a comparable buffed tire and they split, but most importantly because they are heavy. Ask most people who are serious about sand riding and they'll tell you that Sand Stars aren't any good for serious torque or horsepower. Anyone who has had a set for a while (myself included) will find that they start splitting right in the middle of the "v".
Let's talk about weight, everyone knows that if you free up unsprung weight it = free horsepower, so why do people spend all this money on pipes, programmers, cams and filters only to throw a set of heavy Sand stars on even heavier SS rims. That is just plain stupid. You can get the same "V" pattern on a shaved tire and still have the same "flickability" of the heavier-molded Sand Stars. Don't take my word for it though, ask around the other "dunatic" forums and you'll quickly see that people stray away from sand stars once they find out what is best.
I agree with you that there's a lot of people who like them - they're not as expensive as Skat Trak's "Edge" but IMO you get what you pay for.
Thanks, Scuzz!:wink: That's what I wanted to get out of you. Thank you for your view on them. I have never seen any split like you said. Not saying they don't just I've never seen it. I know they are heavy compared to some of the other brands, but not everyone can afford Skats.
That's kinda my point though, people spend money on things that make horsepower, just to take it away with heavier tires. They'll spend $300 on an exhaust and $200 on cams and throw a set of heavier tires when there's only a $80 difference between the 22x11x10 Sand Star's and the same sized Skat Trak Edges.
[these prices were pulled from Rocky Mountain ATV's website for a 450r.]
Most the people who buy them are like me. I go to the dunes 1 or 2 times a year. That doesn't justify and extra $160 bucks for some tires that are a bit a lighter that will get used a couple time a year.
It's only $80, not $160. It's only $40 a tire difference.
Even 80, I would rather spend the extra 80 on something I will use everytime I ride, not just 15-20 hours a year.
Just a matter of opinion.
I hear you. I ride sand about that much a month. If I were you I would buy paddles at all and just rent them when I got there.
john
go on line with scat/trac go with 10 21 8 paddle no more than 10 paddle dubble buff not used on hard drit or trail rides.
go on line with scat/trac go with 10 21 8 paddle no more than 10 paddle dubble buff not used on hard drit or trail rides. on douglas blue lable. or go on line with wicked atv tell them opie sent you.
paddles run about $420.00 a set.
If you get them from Rocky Mountain Atv now you can get them for $395 with free shipping and a $50 instant savings.
$345 aint bad....and it's shipped for that.
    • By Adamb2025
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
