My nephew just took this in part of a trade he made, needs alot of work, but it'll give us something to do. I havent got a clue what it is Ive searched and searched only to hit dead ends theres no vin plate or nothing, hasnt ran in a while.
half the carb is missin wiring is all jacked up, been sittin so long theres mold on the motor.
only code I can find is on the bottom of the motor which is zhx98cm3
any clues as to what model or size it could be? thanks
That is a Yamaha Moto 4 100, probably 1985 or so. Good luck finding parts for that thing. Some of the stuff off the '87 moto 4 champ 100 might fit.
Edited by DirtDemon
I first found this image which led me to believe that was your machine. But when I tried to look up that machine on a Yamaha parts fiche, it does not exhist. However the 85 Badger 80 looks just like that. If you look up a Champ 100 on a parts fiche, the front fender is different than yours. It looks like a Badger 80, but the # on your motor indicates a 98cc engine. Maybe you have a Badger with a Champ 100 motor in it, or the Moto 4 100 does exhist, but is rare and obsolete.
1985 Yamaha Moto 4 100cc for sale in Butler, Pennsylvania - CycleTrader.com
98cm3 would be a 100cc, but like you were told 'good luck!' A carb off just about any old 90 or 100cc can prob be made to work. check ebay for a carb off like a honda atc90- they are usually plentiful and cheap. Good Luck with that one- it's gonna be a project!
    • By HoldenBoy
      Hi all,
    • By Cohen9966
      Looking for something similar for my 2018 Sportsman – this helps.
    • By Freddie
      My first quad and I have a problem. I have a Kawasaki Bayou 300 1997. When I start it. It will go on high idle for about ten seconds before it goes down to low idle. It does this even when I don't touch the throttle or the choke.
      Also, when I give it some throttle and let go. It will come back to fast idle for about ten seconds before it comes down to slow idle. Therefore I have to wait for it to slow up before I can shift. The throttle linkage drops right back to the stop on the carb buy the rpms stay up for a while. If you have any ideas what might be wrong please let me know. thank you Fred
    • By CaptJim
      Hello guys, I hope I am not invading your space, but as you can see the current state of my project here it's not but about 50% ATV. I am hoping that some one here can point me to a wiring schematic that I can reference since the "Complete wiring harness" i purchased from Amazon did not include a diagram of any kind.
      The ones that I am finding on line vary greatly but none show the connections for the separate 5 wire connector coming from the motor.
      Can someone tell me where these wires go?
      Thanks in advance for all help!
    • By WyattLemke25
      Having problems with the battery draining while riding. It has a new battery, it does have eps, a lightbar and a winch. Can ride it for an hour or more just fine, but eventually the battery runs down to the point it can't keep up with fuel injection and it'll sputter, limp, and die. It also throws codes for the throttle position sensor. I'm not sure if that is related or not. Any ideas?
