Anyone,
I have a 1995 Polaris 400L Xplorer that dies everytime I put it in any forward gear. That is unless I push the overide button. Then it acts like Reverse does when your not pushing the overide button. When you put it in reverse it runs like it should but still only runs like the overide button is not pushed. When you push it there is no change....
So in short.
When going forward I have to push the overide button to get the atv to move
When going in reverse i'm unable to utilize the overide button to exceed normal operation.
When in nuatral I have to push the overide button to achieve smooth idle or it dies. When in any forward gear I have to do the same for smooth idle.
When in Reverse the atv will idle smooth without the button pushed.
I hope I haven't confused anyone but this is really starting to get under my skin! :mad:
Thanks,
Tom
Sounds to me like a gear selector switch, the override solenoid, or neutral safety switch. I don't have a wiring diagram to be sure...but it definately sounds like an electrical switch issue.
I'm wondering if that is some sort of limp mode...nah..maybe it's too early of a year.
* Added Year and Make into your thread title.
Well I figured it out....
Ended up pulling wire by wire until the problem cleared. When looking at the front of the wiring panel... it was the bottom left Black Wire...
I believe it was an issue somehow with my override button grounding out when not depressed.
Now I have full speed in reverse without using the override.... and no issues with any other features.
Tom
Tom
Nice...:yes:
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
