In the last five years I've had the pleasure to ride what
I believe is one of the finest ATV's My '05 'Desert Edition'
Honda Rubicon. From the desert flats in 100° heat to elevations
of 10,000ft, in temps of 19° Through boulder infested dried up
river beds and wash's and a occasional run in fender deep snow
not once did I have to walk or be towed back to camp !
This has allowed me to rack up 9,200 issue free miles and the
opportunity to ride and meet with some fantastic people across
the state of Arizona and points beyond...it's been a most excellent
adventure to say the least.
At this point in my life I have come to the reality that I'm not as
young as I once was and the need for an IRS suspension was becoming
more attractive after a long day of exploring in the desert southwest.
So I'd like to present My 2009 "Desert Hawk" Edition Rincon
My goal for this unit was to have all of the thing's that made the Ruby
the ultimate (for me) ATV with just a bit more snort and a cushy ride.
With this idea and information I've read on all of the site's I visit
I do believe my goal has been accomplished !
Nothing like this can be achieved with out some help so I'd like to
give a shout out to the Staff of Coyote Honda in Avondale, AZ.
ARIZONA'S LEVEL 5 Honda Powerhouse Dealer.
Left to Right Parts Manager Matt Service Manager John, And Master Technician
Dave who kept the Ruby in top running condition since 2005.
This will be the last time I'll ever see this on the Rincon !
Thanks BuckBilly :wink:
Ajmboy, Not yet and with a few things coming up this weekend
it's looking like next week :aargh:
A buddy of mine has two '08's and I've racked up a few miles on his
the thing I'll really be watching is the off camber areas.
Well congrats and have fun breaking it it!!! Looking forward to some riding pics!
  • 4 years later...
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By Chucksta
      So.. It has now become cranky about changing from "drive" to "reverse". Sometimes it's seamless as it's always been, other times it just goes "click, click....click, click " when going from reverse to forward, or from forward to reverse..  Then it gives up and just stops at neutral.  Only thing that seems to help is to give it a bit of a bump / wiggle with my own weight. Any ideas as to what to check? It's low miules / hours .. Dealership maintained..
    • Guest
      By Guest
      I have a 2022/23 Honda Rubicon, and was wondering if there is an exhaust deflector available.  I have a rear basket w/ chainsaw mounts, a winch on the rear, and a hitch.  When I am working at the rear of the quad, the exhaust puffs and hits us, while we work.  It is quite annoying and wound like to be able to direct the exhaust downward.  Is there anything that you know of that would work w/o creating any back pressure that might disrupt the engine?  I’ve been searching for something like this, but can only find ones for small engines and silencers that would interfere with the winch.
      dave
    • By hporter1208
      Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
    • By HondaRubi2022
      Hello,
      I have a 2022 Honda Rubicon and I have an issue where it won’t start, when I turn the key for power nothing lights up and it won’t start but the lights will turn on with the light switch, I’ve checked all fuses and they’re good, I don’t have a wiring schematic I’m not sure where to start, I checked the ignition fuse when I turn the key on and there’s no voltage there, I used a jumper wire from the batter to the top of the ignition fuse and then it works fine and starts fine but as soon as I turn the quad/key off it won’t start again until I jump the ignition fuse with battery power, just wondering if anyone could give me some tips where to go with this or if anyone has had the same issue, thank you.
