I recently bought a Polaris 95' Magnum 425 4x4 and when i bought it went into gear with a good shove (Automatic ) anyways now it wont go into Hi,Lo, or R. I hear it click when i forcefully put it into gear but wont move. Also i wanna note that after a week of having it (never offroaded wit it yet only because the rear was loose and i had to replace bushing to keep it from shaking) That it went foward in Hi,LO, N, and R than just wouldnt go back into gear after that. Any ideas?
I had a similar issue where it would grind really bad when going into gear. I turned my idle down just a bit and actually also took off the belt cover and cleaned the clutch weights and clutch unit. It was pretty dirty. It works great now maybe u could have some luck
  • 8 months later...
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
