Similar Topics
By gohndd
Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
By ggreen
Sorry if this is in the wrong section,I didn't really consider it technical or needing advice. 2006,Linhai 300cc.What I was hoping was to find someone with the starter idler gear pin length and diameter. I've had the cover off alot of times and never realised there should be a pin from the case that meets the cover holding the starter gear in place. Now,a deepwell 1/4 in drive,5/16 deep well sits in the pin holes perfectly. Should I cut a lock ring groove in the end of it like a factory pin? I was thinking of just tack welding a washer to the end?
By Cheetah
Hello,
recently I removed my starter because it was to slow so before buying a new one I thought cleaning it. So I did and it did went much better.
The thing is I replaced it exactly as it was but since then the starter goes freely like there’s no dentelywheels.
Did I do something wrong ?
By JGou
Have an axis 500 bought from Lowes.. Have had to adjust the shift linkage 1/2 doz times in the last year.. Now the UTV is stuck in neutral.. Seems to shift ok through gears but neutral light never changes, and wont move at all when running.
Only have 13 miles on this 4x4 and have had no other problems... Any help would be greatly appreciated.. Thx, Jay
By afa913
Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
Similar Tagged Content
- 3 replies
- 8,593 views
- 3 replies
- 4,078 views
- 0 replies
- 3,038 views
- 0 replies
- 2,949 views
- 2 replies
- 2,685 views
Gallery Images
