I have just recently purchased a 1998 artic cat bearcat 454 2x4!
It had been sitting up for about 2 years and needed some major work!
I replaced the cdi unit and regulator and freed up the brakes! Now I was breaking
down the carb, cleaning the jets and all and noticed that one of the ears
that hold the float in place has been broken off!! I opoxyed it back on, and everthing
seems to be fine now! But as I was looking for carbs I can't find an aftermarket carb
anywhere! A brand new one is from 400 to 500 bucks and I can't find a used one!
Does anyone know a different brand or an aftermarket carb I can use on
my 98 bearcat 454?? Thanx alot!!
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By fixitforfree
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
