1999 Kawasaki Lakota, removing balljoints?
Similar Topics
By glencam
Hi everyone new to this forum so thanks for taking the time to read my questions. I have an older 88 Big Bear 350 and it wont go into Hi range ....well I think its Hi it wont go into it may not go into low range it will go into reverse when i shift the shifter it moves all the way back (i removed the pin and manually shifted it ) forward is reverse middle is low and all the way back is hi but when in hi position its like its in N no forward movement of the machine in any gear. I did get it to work once but then shifted to reverse to get it out of garage and the problem returned.
Where is the Hi/Lo gears actually situated? by removing the right side cover to expose the clutch will I gain access to the shifter?
The "Middle Gear" housing on the other side (left) does it take gear oil ?
thank you
By BlueBowtie
Is it possible to put a motor from a big bear 350 into a timberwolf? Reason I ask is that I have a timberwolf with a bit of a rod knock, and I have big bear with a bad rear end and axle with a good motor. So, is it possible?
By Dan Kroes
Does anyone know what size wrench I need for the middle axle jam nut on a 2001 Polaris Sportsman 500 6x6? same part used on rear axles of these models.
2000 INT'L BIG BOSS
2001-2002 INT'L BIG BOSS 6X6
2002 LUH 6X6 P
SERIES 10 PTV 6X6
1998 SCRAMBER 500
1998-1999 SCRAMBLER 400
2001 SCRAMBLER 400 2X4
1999 SCRAMBLER 500
2001-2002 SCRAMBLER 500 2X4
2001-2002 SCRAMBLER 500 4X4
2002 SCRAMBLER 500 4X4 FREEDOM
1999 SPORT 400
2000-2008 SPORTSMAN 6X6
2005-2007 SPORTSMAN 6X6 MV
2000-2002 TRAIL BLAZER
1999 TRAIL BLAZER 250
2002 TRAIL BLAZER FREEDOM
2000-2002 TRAIL BOSS
2001 TRAIL BOSS 325 SE
2000-2001 XPLORER
2001 XPLORER 400
2002 XPLORER 4X4
By Charlesbrown
By STLJ
Hope everyone is having a great weekend,
While riding my quad just quit, I mean dead. No life on the dash, no crank and obesity no start.
Had a quick look under the plastic, batt reading 12.7v power at the key switch.
Changed the power pack, still no luck.
Anyone else have similar problems?
I don't see a fuse box/panel, is there fusible links in the system? If so where di I start looking?
SK
Similar Tagged Content
- 0 replies
- 4,254 views
- 6 replies
- 4,636 views
- 0 replies
- 2,664 views
- 0 replies
- 1,558 views
- 4 replies
- 6,379 views
Gallery Images
