By 97kingquad
By Does_This_Look_Bent?
Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
By Topendcol
Col
By alexwv1863
Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
