I got a 09 AC 150 for grandson at a powersport auction still in the crate. when I put it in gear it engages but takes a lot of throttle to get it moving.
Hey thanks for input Ive got a 07 500 artic cat with a foot shifter don't see one on this one except for the foward, neutral, reverse shifter. could be hung in a gear, they complain it doesn't go fast enough seams to be wound out at about 19 mph I put oil in the engine don't know about the trans no book came with it
Edited by lobo
clarified shifter
    • By 97kingquad
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
    • By 88Tecate4pal
      Anyone have an assembly? Thumb throttle and cable to carburetor?
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By alexwv1863
      Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
