I got a 09 AC 150 for grandson at a powersport auction still in the crate. when I put it in gear it engages but takes a lot of throttle to get it moving.
Hey thanks for input Ive got a 07 500 artic cat with a foot shifter don't see one on this one except for the foward, neutral, reverse shifter. could be hung in a gear, they complain it doesn't go fast enough seams to be wound out at about 19 mph I put oil in the engine don't know about the trans no book came with it
Edited by lobo
clarified shifter
    • By Elk
      2002 Polaris Magnum 325
    • By 97kingquad
    • By Does_This_Look_Bent?
      Hey everyone, I just replaced the carp on my 98 Kodiak 400 with PN#4SH-14101-00-00. It starts and idles perfect, but once it’s good and warmed up, it bogs out at 3/4 throttle or more… it sounds like it’s bouncing off a rev limiter haha… I tried the air fuel screw, all the way in and out 2-1/2, and it made it a touch better… tried 2 turns and no different. Am I missing something?
    • By Pure_Michigan
      Hello everyone.  This is a Go Cart and not a typical "ATV" but it has an engine so I'm hoping someone can help me.  It's a Helix FTX with a Manco 150cc engine.  The engine will start and idle for awhile, but will not take even a small touch of throttle.  Stalls.  It seems to take throttle and rev up when you first start it cold, but in just a minute, it will not take any throttle.  I've replaced the Fuel valve/Pump on the fuel tank with no joy.  It's a nice little cart, but without a workable engine, it's a boat anchor.  I'm not dumb when it comes to small engines, but this one has me stumped.  I'm running out of options.
      I'll mention that while it is idling, it will sort of "cough" every 6 or 8 seconds and then recover and idle again.  Eventually one of those "coughs" causes it to stall.  It will start back up pretty easily, but as I said, it absolutely will not take any throttle and then it will cough and stall a minute later.  I thought it could be timing, but there is no "adjustment" for timing on this engine.  I downloaded the user manual and it mentions nothing about timing and is pretty much useless as a service guide.  It just shows the basics.  I'm attaching the manual so you can get an idea of the machine I'm dealing with.
      Any input would be greatly appreciated.
      Kind regards,
      Don
      Manco-Helix-6150-150cc-Owners-Manual.pdf
    • By 88Tecate4pal
      Anyone have an assembly? Thumb throttle and cable to carburetor?
