Similar Topics
By dlgg7
I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ??? -
By gatorschevy
just picked this one up and was wondering how you know for sure the the 2-stroke oil is going into the motor? I don't want to blow this thing up; I know I can unhook up the parts and just mix it myself but that's another can sitting around
By mfay1
Can anyone tell me where the fuses are on a 2005 Polaris Sportsman 400. The winch suddenly stopped working. I put a tester on it and its not getting any juice. Please help! (I dont even know if the machine has a fuse for that)
By 800CCBRAAAAAAP
I tested the stock OEM coil, and got 25ohms. But even after applying voltage, I cant get anything to magnetize to the coil Does anyone have a way of testing the 4x4 on-demand coil?
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
Similar Tagged Content
- 11 replies
- 597 views
1996 Yamaha Timberwolf Rebuild/Repair
By Chris Chitwood,
- timberwolf 250 yamaha engine
- 1996
- (and 1 more)
- 9 replies
- 3,085 views
- 3 replies
- 7,381 views
- 0 replies
- 2,215 views
- 2 replies
- 3,052 views
Gallery Images
By mike83,
By nemesis,
By Guest,
By cjsservices,
By trouble4fun,
By Guest,
By blahhhh,
By mike83,
By monkey420,
By Chomp,
