I have recently rebuilt my yfz 450 as a lot of you know from my other posts. Well, they bike runs great. Very strong but i'm kinda wanting to sell it to build my 06 raptor 700r with 50th anniversary plastics. I've had a few potential buyers of the newly build 480 but all have turned out to be scams. I had an offer last night from a guy and after i covered all of my basis', he emails me this morning saying "well i did some research on the cylinder works cylinder you have on it and i found out that they tend to crack". Does anyone know if this is true? I've had no trouble with it. It has a 13:1 comp cp piston with a stock stroke 06 OEM crank and rod. The guy tried to get me to email the vin to him buy i refused and then told him if he was bringing a check, to make sure to cash it before he got here and the next email this morning was the about cylinder works cylinder having cracking issues.
Chad
I know nothing of any paritcular issues with the Cylinder Works cylinders, I think this guy may just be trying to get you to drop the price. I only know one guy who has run that Cylinder Works bigbore setup on his YFZ and he has not had any problems.
I agree with DD, sounds like a price reducing attempt.
    • By oztrax
      MAX 4 6X6 2008
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By Gtc4d
      Thanks.
      Todd
    • By jordan_ATV
