guys and gals I have a 2002 Kawasaki 650 praire it sparks once on each cylinder then stops i have replace wire harness, CID, regulator some one please help :aargh: and why only 1 time if it was the pickup coil it would not spark at all need help
thank eh
Edited by lamhound
Did you replace it with a new cdi? There may be sensors on that machine that will limit spark to slow the egine down if let's say the belt was slipping or it had a rollover which could be causing an issue. Usually it would be a cdi or coil issue, I would think.
* Added issue into your thread title.
A bad pickup coil is not necessarily out of the question, sometimes when they are bad, they will only spark once or twice once the start button is released. They have a tendancy to act very strange when they go out. I would also take into consideration the advise that Ajmboy gave you, there could very well be a sensor or switch that is causing your problem.
i will try resetting the belt switch or the cvt or what ever they call it i did replace the coil very weak spark like i say will try and re set cvt switch will keep you posted
thank eh
mike
well boys and gals it looks like i found my problem i changed cvt switch no luck i change the tip over switch no luck replace pickup coil no luck that's when i got real mad :aargh: switch out wiring harness that's when i came to the problem the ( ignition switch) :laugh: it was not push in good and didn't have a good contact put the spark plugs back in boy she run good
man we'll go muddying by Sunday can't wait
anyway thank folk for your input
Michael w
:laugh::laugh::laugh::laugh:
    • By TomJulio
      My 1992 TRX00 recently stopped firing.  I understand this is a common problem. I have ordered an aftermarket CDI unit.    TJ
    • By tflack500tbx
      Background,
      Any Ideas?
    • By marlon smith
    • By kevinohio
      My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
    • By dkgg5755
