Electrical switches don't work when the contacts get too dirty. I can't tell you how many times I have fixed someones power windows or lights/blinkers just by taking the switch apart and cleaning the contacts inside. If all the wiring seems ok, and power is getting to the key switch, but not coming out of it, try taking it apart and cleaning it up, or, just replace it. If power is coming out of the switch, check for power on the low current trigger wire at the solenoid. If there is power, the problem lies in the starter or solenoid. If there isn't power, then the problem is in the wire between the solenoid and the key switch. Good luck.
  • 3 months later...
They could be under the hood too. Sometimes the protective wrapping gets water inside and corrodes the hell out of them. I belive there are three of them, 2 run the electrical system and the third one works the 12 acc plug.
They look like this...
[ATTACH]571[/ATTACH]
20 amp breaker goes to the ignition switch and the other 20 amp breaker to the fan switch.
  • 11 years later...
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
      View File 2020-2026 Polaris Sportsman XP 1000 S service manual
      Download the 2020-2026 Polaris Sportsman XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Sportsman XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, clutch and transmission repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for ATV owners, mechanics, mud riders, trail riders, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, repairing, and rebuilding the Polaris Sportsman XP 1000 S high-performance utility sport ATV.
      Polaris Sportsman XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and maintenance schedules
      2020 Polaris Sportsman XP 1000 S service manual PDF
      Sportsman XP 1000 S wiring diagram
      Sportsman XP 1000 S maintenance schedule
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Sportsman XP 1000 S for trail riding, mud riding, hunting, utility work, and extreme off-road performance.
