I don't think your CDI box is the problem, I would be more suspect of a loose connection or bad ground wire. Perhaps a fualty sensor. I am moving this to the UTV forum and changing the thread title a bit. Also, what engine size do you have? We would like that to be added to the thread title as well.
    • By Asand211
    • By TravisCr
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
