When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
Timothy
2000 Big Bear 4x4 400.
do the front and rear drive shafts have to be lubricated? they have boots on them and i was wondering if i had to pull the boots off and grease the "U" joints? These are the ones close to the engine front and rear.
