It could be the alot of things. How does the machine run other aside from the idling problem? Has the machine been sitting for a while? If so, I would open the carb up and give it a thorough cleaning. It could have an air leak somewhere, possibly a leaking crank seal, or a leak in the intake area, maybe where the intake boot bolts to the motor. Also, check the air cleaner and try a new spark plug. I would also do a compression test.
Edited by DirtDemon
It could be the alot of things. How does the machine run other aside from the idling problem? Has the machine been sitting for a while? If so, I would open the carb up and give it a thorough cleaning. It could have an air leak somewhere, possibly a legal crank seal, or a leak in the intake area, maybe where the intake boot bolts to the motor. Also, check the air cleaner and try a new spark plug. I would also do a compression test.
What he said.
LMFAO, I never noticed that, but you are right, that does look like Sgt. Slaughter, it is actually a picture of his Father-in-law. Hey Admin, is your Father-in-law Sgt. Slaughter? Have you been holding this info from us?
In order to stay on topic, I will ask bbbbirdman if he has had any luck figuring out his problem. So what it be birdman, any luck?
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Ethan7387
    • By mmikesell
